whats going on with my clutch
Old Sep 9, 2003 | 11:26 AM
B16SI00's Avatar
B16SI00
Default whats going on with my clutch
i got a new act stage 2 clutch 5months ago and today my clutch pedal got preatty loose and is hard to shift in my gears does anyone know whats up. my clutch got replace in a honda dealership. thanx
Old Sep 9, 2003 | 07:51 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
if you have a hydrolic tranny, check the clutch fluid in the resevior. all you need in there is brake fluid.
Old Sep 11, 2003 | 02:13 PM
crxb16er's Avatar
crxb16er
also check the hydrolic lines for any signs of damage, and leaking fluid anywhere, look on the floor under the clutch pedal that slave cylinder went out on my lil bros civic pretty early
Old Sep 21, 2003 | 06:38 AM
agileauto.com's Avatar
agileauto.com
sounds like a fluid problem. do you hear any clanking around in the engine compartment? maybe the honda tech was also co-starring as a dipshit mechanic with no experience? may not have properly clipped in the release fork or something.
Old Sep 24, 2003 | 09:35 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
Check the slave cylinder for leakage ACT is known for blowing shit out. I blew my engine in my 95 AWD talon (crank walk).
Old Sep 24, 2003 | 09:41 AM
95civicEX_h22's Avatar
95civicEX_h22
Slo N Low
:werd:
Old Sep 30, 2003 | 07:21 PM
h22avid's Avatar
h22avid
Sleeper...Creeper...
If you don't have any hydrolic / fluid issues as previously suggested then check the actual clutch pedal.
There should be two nuts holding the clutch pedal to the bolts from the master cylinder. Then there should be a third bolt going through the top of the pedal into the underside of the dash which keeps the pedal from flexing on the firewall when you push the pedal down. If the pedal flexes then the hydrolics of the master cylinder aren't fully accuated.
I had problems getting my civic into gear when I pushed the clutch in Turns out it was the third bolt that held the top of the pedal to the underside of the dash area. The bolt was loose causing the pedal to flex with the firewall... I tightened it.... the car got in to and out of gears just fine.
:thumbup:
