98 Civic Oil Leak. replaced cover gasket, o ring and vtec solenoid what else?
Old Jun 19, 2012 | 06:25 PM
TriniSpeed's Avatar
TriniSpeed
Default 98 Civic Oil Leak. replaced cover gasket, o ring and vtec solenoid what else?
It was definitely leaking from the valve cover and vtec solenoid
Replaced valve cover gasket, both gaskets on the vtec solenoid
and on the distributor o ring shaft.
Still have a leak.
Any other suggestions?
I will post pics this week
Old Jun 20, 2012 | 02:39 PM
hitman619's Avatar
hitman619
SDSU Basketball
Did you check the cam seals?
Old Jun 22, 2012 | 12:15 AM
TriniSpeed's Avatar
TriniSpeed
I found this video on you tube.
Looks right where mine is leaking
Old Jun 22, 2012 | 12:27 PM
TriniSpeed's Avatar
TriniSpeed
Here is where I am seeing the oil
Here is the Vtec Solenoid. I already replaced the 2 gaskets here
