99 Exhaust questions
Old Sep 7, 2003 | 11:32 PM
Elevatorguy's Avatar
Elevatorguy
Default 99 Exhaust questions
Guys,
I am replacing the muffler assembly on a 99 Civic EX with the V-TECH engine. When taking the muffler off, I tried unbolting the hardware from the muffler side of the flange (where the small coil springs are on the special bolts). Well, both of the "bolts" broke off just where the threading starts on the. Yes, the muffler is off, but the remainder of the hardware is still in the nuts that are on the flange coming from the resonator. My question is this. Are the nuts on the resonator side of the flange welded on to the flange itself or are there supposed to come off? I got onto them pretty well with a 15mm wrench and they didn't want to budge. If these are welded onto the flange, how do I go about removing the rest of the bolt? There is about 3/4" of the bolt sticking out the back of the nut and I tried, with no luck, to spin them out with a pair of vise-grips. Any help will be graetly appreciated.
Thanks in advance,
Todd
Old Sep 7, 2003 | 11:36 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
I doubt they are welded. Probably just bonded from rust. I had similar problems that WD40 fixed.
VTECH.....makes great phones
Old Sep 8, 2003 | 04:04 PM
Snoopy's Avatar
Snoopy
been there done that
Old Sep 8, 2003 | 05:09 PM
96GreenCivic's Avatar
96GreenCivic
so on my 96 civic ex, i can just unbolt and install my own cat back?
Old Sep 8, 2003 | 05:12 PM
Snoopy's Avatar
Snoopy
yes. if the bolts are rusted, spray them with penetrating oil and let it soak.
Old Sep 8, 2003 | 06:00 PM
96GreenCivic
snoopy , have you done your own cat back?
Snoopy's Avatar
Snoopy
you really are a noob :chuckles:
Old Sep 9, 2003 | 02:39 AM
Elevatorguy
I talked to the dealer today guys. The nuts are welded on the other flange. Anyideas for getting the broken bolts out?
Thanks
Old Sep 9, 2003 | 04:05 AM
shifty35's Avatar
shifty35
Happened to me. I had to heat the leftover bolts with an acetylene torch and twist them with a pair of pliers, but they cam right out. Then again, torches are a little hard to find...
Old Sep 9, 2003 | 09:07 AM
IamThFEAR's Avatar
IamThFEAR
Those nuts are welded into the b pipe, look at this way, your ready for a whole new catback right? Well nows the time to do it.
