puttin in a shortshifter
Old Sep 7, 2003 | 06:52 PM
tas31804's Avatar
tas31804
Default puttin in a shortshifter
hey i got my 92 integra about 2 months ago and i was wonderin how do i put in a shortshifter?????? is a long process etc....
any directions would help
thanx
Old Sep 7, 2003 | 08:02 PM
FL_Civic_Rider's Avatar
FL_Civic_Rider
Drive it like it's a Taco
I put in my short shifter on my car like 1 month after i had, and this was my first car installation thingie.
It's actually pretty EZ if you just look at it under the car.
pull of ur center console, knob shift boot (if needed) etc so the only thing inside ur car is the stick itself.
under your car there is a bar/rod (not sure what it's called)
but the end of it connects to your shifter.
the end of it should be a |_| shape, with the shifter inbetween
each side of the "U" with a bolt holding it in place.
take off the bolt,
pull the shifter down from under the car,
put up new shifter from under the car,
put bolt back in place(and spacers if they come with package)
and your done.
this is the first time I've tried explaining this to someone, and I probably took the long way to explain it, but owel.
hope it helps tas!
edit-
oh yeah and this took me 20 mins tops,
and that's with jacking it up, taking out console etc and putting it all back.
Old Sep 9, 2003 | 07:29 AM
BonzoAPD's Avatar
BonzoAPD
team integra has a great how to article on this. Do a search on there and you'll find it.
Old Sep 9, 2003 | 05:52 PM
FL_Civic_Rider
i just redid my shifter today, took out my red one, but in a spoon one, and then took out my freidns oem and put in the red one.... i don't remember it being so hard ;(
Old Oct 27, 2003 | 02:43 PM
SOHKeg's Avatar
SOHKeg
putting in a short shifter was no problem. did it for the first time and it only took me 30 min...:fawk:
Old Oct 27, 2003 | 04:35 PM
bri's Avatar
bri
wow you're cool. :fawk: :fawk: so how does that help?
Old Oct 28, 2003 | 08:32 AM
SOHKeg's Avatar
SOHKeg
kiss it -->:booty: since i'm too cool for you i'll let you get back to the daily grind hjerk:
Old Nov 26, 2003 | 07:22 PM
dawrenn's Avatar
dawrenn
:thumbup:
File Type: jpg
Old Nov 27, 2003 | 03:14 AM
dawrenn's Avatar
dawrenn
:thumbup:
Old Nov 30, 2003 | 12:37 AM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
I heard stories that short shifters wear out the synchros really fast. Fact or Fiction?
