which gauges should i get
Im planing on getting a D16Z6 engine soon. Im also getting a 3 pod a pillar cluster. What would be the top 3 i should put in?? Im planing on using Autometer Colbalt series gauges.
air/fuel isn't worth the time, unless you rig a wideband to output a narrowband signal to the gague... otherwise it's as accurate as your girlfriend sticking her nose out the window and sniffing.
For turbo, EGT/BOOST right where you can see it, and oil temp, coolant temp, and oil pressure, still visible, but mounted in a secondary location, like by the radio.
-PHiZ
-PHiZ
I'd do a real water temp (cause the stock one lies), oil pressure, and obviously, boost. a/f = eyecandy, and everything else isn't necessary if you get your car tuned. On that note, I really don't like pillar pods. I'd look into a din panel pod, or guage bezel pod, personally, but thats just MO.
I'm with PHiZ. If you want A/F, get an APEXi turbo timer. It's 10X as useful as a A/F gauge and happens to have a o2 meter, A/F ratio, and a voltmeter built in as well. So for the third gauge, get a clock
Otherwise, get a 2-gauge a-pillar. 3 gauges will obstruct your view, in fact I hate my a-pillar mount. You can get fuel pressure and oil pressure in a bezel-mount.
