I Need Interior Paint!
Old Aug 25, 2003 | 07:07 PM
FL_Civic_Rider's Avatar
FL_Civic_Rider
Drive it like it's a Taco
Default I Need Interior Paint!
I'm looking for HIGH QUALITY interior paint and sealer.
Not just spray paint, but can's of paint that i can use a brush with.
Looking for a website or company if anyone can help.
PS.
I need good quality like i said. not stuff that's gona flake or peel in a month or two.
pls email me or pm me
Make_emsizzle@hotmail.com
Thanx! adam
Old Aug 25, 2003 | 10:34 PM
slammed91-hatch's Avatar
slammed91-hatch
if you want high quality paint use actual car paint....pull the pieces out and paint them and clear coat them like you would a car
Old Aug 29, 2003 | 09:09 PM
crx304's Avatar
crx304
larger than avg member!
ok.... the reply is close to accurate!
here is what you need to do.....
1) get some 400 grit sandpaper
2) buy desired paint
3) buy a chemical called MEK
1) sand the area to pe painted
2) wipe w/ MEK "really good"!!!! you can get this at automotive paint supply or fiberglass shops.
3) spray 3 "LIGHT" coats of paint or untill desired coverage.
alot of people have the misconsception of "IHAVE TO BUY INTERRIOR PAINT" because the paint won't adhear to the interrior panels. the reason the paint wont stick is because of the "Armor all" type products that contain oils in them,that people use.
if you do a good enough prep job w/ the right materials, you can make any paint job look good and last.
mike
Old Aug 29, 2003 | 10:13 PM
FL_Civic_Rider
Sweet thank you very much mike!
