Jumping/Clunking When In Gear But Off The Gas
Old Mar 27, 2012 | 07:08 AM
mdb20's Avatar
mdb20
Marky Mark B.
Default Jumping/Clunking When In Gear But Off The Gas
I'm pretty sure the motor mounts are torn/destroyed. Would this cause the car to jump or clunk when in gear but off of the gas quickly, like if you were to blip the throttle? The gear shift lever also moves back and forth when on and off the gas. Are these things correlated? Has anyone had issues that sounded like these and if so, what was the cause and the fix?
Thanks
Old Apr 14, 2012 | 10:39 PM
Tobra's Avatar
Tobra
Could be CV joint, but I think you probably have the call on the motor mount
Seems to me that two of them are easy to change, and one is a PITA
Old Apr 25, 2012 | 07:04 AM
samule's Avatar
samule
what does you mean it is little bit confusing not clear.
