Crazy Ass O2 sensor problem
Old Aug 22, 2003 | 03:03 PM
DropSquadCivic's Avatar
DropSquadCivic
Default Crazy Ass O2 sensor problem
I just went over to my friends house and helped him convert his 7wire o2 setup off of his VX harness to a 4wire did everything right and is still throwing a code and is still running rich, does ay body know how to solve this?
P72 ecu
vx harness on a GSR in an EG
Old Aug 22, 2003 | 08:59 PM
undrgrndhaqer's Avatar
undrgrndhaqer
Mr. EG
Your out of luck buddy. Sorry to tell you
Old Aug 22, 2003 | 09:04 PM
undrgrndhaqer
Mr. EG
Maybe those connectors we used on the o2 arnt getting continuity. Just maybe, those connectors didn't work at all... Just a thought.
Old Aug 23, 2003 | 11:01 AM
DropSquadCivic
then how did the a/f read when we started the car up?
Old Aug 23, 2003 | 11:06 AM
DropSquadCivic
i can bring my volt meter over and we can check the continuity on it, but i don't think that it, if the a/f is reading then the o2 has to be gettin power on it then.....
Old Aug 25, 2003 | 07:39 AM
v4lu3s's Avatar
v4lu3s
if you are getting codes you need to trace eahc wire and test to make sur eyou got good connections and the right pinouts etc...
Old Aug 27, 2003 | 11:55 PM
PHiZ's Avatar
PHiZ
BOOST GOD
REmember signal wire off the O2 sensor is shielded, it's sensitive to RF interferance.
Check your splices, I used blade connectors in the passenger kickpanel, and had to swap them with butt connectors, fixed some of my codes.
-PHiZ
Old Aug 29, 2003 | 08:50 PM
undrgrndhaqer
Mr. EG
what is a blade connector?
For the full process of our o2 swap goto:
http://honda-tech.com/zerothread?id=605946
Ugh
Old Aug 29, 2003 | 09:59 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Ugh
aka "spade" connector
...replied to H-T post.
-PHiZ
Old Aug 31, 2003 | 09:28 AM
undrgrndhaqer
Mr. EG
Posted the wiring connections on H-T. It has to be the connectors b/c im sure the wiring is correct. Also, re-read this thread. He said because the a/f gauge was getting a reading. Not really. When car is on, the gauge would show half the led spectrum in a fading manner. If I hit the gas, all would get brighter but wouldn't move in an individual led. Get what im saying? It's like its not getting a strong enough reading. ( connection problem maybe?)
Ugh
