how to check coil....
Old Aug 21, 2003 | 06:34 PM
dinan's Avatar
dinan
Default how to check coil....
I don't have any spark coming out of the coil on a '91 accord. Is there a way to check the coil besides replacing it? Anything else I should check first?
Thanks,
Bob
Old Aug 21, 2003 | 10:04 PM
drift's Avatar
drift
Flaccid Member
coils are usually potted for shielding and vibration resistance, so checking it wouldnt be easy, except for a conductivity test.
ignitors are a common failure in Hondas, which can obviously cause a loss of voltage.
Old Aug 21, 2003 | 10:17 PM
firebane's Avatar
firebane
get a manual that tells you how-to test the coil then get a Multi-Meter and you can test it.
