low coolant levels
Old Jul 12, 2002 | 02:14 PM
Paul's Avatar
Paul
Eater of Rice
Default low coolant levels
anyone have to refill their coolant reservoir every week or couple of weeks? is this a problem? could it be from the 90+ degree temperature the pass month?
Old Jul 12, 2002 | 03:55 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
your coolant doesn't evaporate when it gets hot, it should be a sealed system in there. You probably have a leak somewhere.
Old Jul 12, 2002 | 08:26 PM
pomansouth's Avatar
pomansouth
look below your car after leaving it parked there got about 15 mins and if there is any liquid under your car check it out and see what color it is and smell it. if it green and has a funky smell then you are leaking coolant and need to get some radiator stop leak or something.
Old Aug 17, 2002 | 09:48 AM
Chin's Avatar
Chin
Mine too. need to add coolant twice a week! But didn't see any coolant leaks under car or around upper horse. Just changed timing-belt and water pump a few weeks ago. Any help?
BTW, mine is 91 integra LS. Thanks !!!
Chin
Old Aug 17, 2002 | 11:06 AM
evo119's Avatar
evo119
GO GIANTS!
Integra's are known for weak radiators. The end tanks are made of plastic and crack over time, so that's probably your problem. Either that or one of your hoses is cracked. I have the same problem I just found out last week. In the engine bay, do you see any water spots anywhere?
Old Aug 22, 2002 | 06:05 PM
Chin's Avatar
Chin
GOt some water spot under passanger side ground. Will have the radiator and horses replaced this weekend. Thanks.
Old Aug 24, 2002 | 11:35 AM
Chin's Avatar
Chin
Yes, found cracks near the top plastic part. Got a new csf metal radiator and horses installed. It runs great now BTW, total cost me around 310 parts and labors. Is it too much for the job?
Old Aug 24, 2002 | 11:39 AM
b00gers's Avatar
b00gers
metal ones are cool. i dont know the brand, but $310 sounds like a good deal. i think my friend paid more for a OEM replacment.
Old Aug 26, 2002 | 07:26 AM
Chin's Avatar
Chin
Here is one more credit to the new radiator. Before installed the fan awlays turns on after a highway drive but now the fan is quite. Also, engin is running at lower temperature.
Old Aug 26, 2002 | 07:51 AM
reech-around's Avatar
reech-around
RIP Woong.
that's very cheap for an all metal radiator. i paid $140 for an OEM replacement (didnt care about going all metal because i'm not keeping the car forever).
carta79
Engine Swaps, Tech & Tuning
12
Mar 13, 2006 04:13 PM
CivicRacr
92+ Civic/EL & Del Sol
3
Jul 5, 2004 06:40 PM
Paul
Jul 12, 2002 07:02 PM
