Rear speaker wire - which on is + and _
Old Aug 14, 2003 | 02:26 PM
3 plus 1's Avatar
3 plus 1
Default Rear speaker wire - which on is + and _
I have the rear speakers out an I'm about to put my inifinity Kappas in. One problem. I dont know which wire is + and which is -. There's a red/white striped and brown/white striped on the passanger side and a blue/yellow stiped and white/grey striped on the drivers side. I dont have a voltometer
Old Aug 21, 2003 | 05:36 AM
99GSRbeerman's Avatar
99GSRbeerman
There is a speed limit?
go buy a 2 dollar volt tester :boink:
Old Aug 21, 2003 | 06:35 AM
NS98GSR's Avatar
NS98GSR
you got a DC2? how on earth do you gain access to the speakers in the back? I've been planning to replace my rear speakers for a long time. Mine are just disconnected right now.
Old Aug 23, 2003 | 03:48 PM
WhiteLitening's Avatar
WhiteLitening
I'm like dis'........
In the back speakers, those speaker grilles just pop off, but ya gotta get the whole panel off to actually get a new speaker in.
Old Aug 24, 2003 | 01:22 PM
ShastSmae's Avatar
ShastSmae
lick the wires :thumbup:
Old Aug 24, 2003 | 02:36 PM
3 plus 1's Avatar
3 plus 1
I figured it out a while ago. They sound pretty nice. Had to do some custom fabbing, but it came out alright. Here's what it looked like when I was doing it though -
:happysad:
File Type: jpg
Old Aug 24, 2003 | 07:26 PM
st0ckWhee1s's Avatar
st0ckWhee1s
Wow....... All that for some speakers. I want to see a final pic.
As for positive and negative..... take a battery, and from behind your headunit connect the pos to pos and neg to neg. Connect the speeaker as well. When you connect the battery your speaker will move. If the speaker pulls in it's wired backwards. If it pushes out it's correct.
Now for the easy answer.
Passenger side.... Red/ Yellow is positive and Brown /White is negative
Driver side.... Blue/Yellow is positive and White/Slate is negative
Old Aug 28, 2003 | 11:11 PM
Toyz51's Avatar
Toyz51
On a honda, the rule of thumb is if it is red or blue it is positive and the other one will be negative.
Old Aug 30, 2003 | 11:43 PM
Spec R's Avatar
Spec R
what amp is gonna power those?
DB Squad
Integra Forum Moderator
Old Aug 31, 2003 | 01:15 PM
3 plus 1's Avatar
3 plus 1
Speakers are running off an Alpine 9813 (60wx4). And thats real. I had to wire the damn thing direct to the battery (it'll run with the key out of the ignition too). Sounds pretty good. But kappas are known for shitty bass and for the time being I've got some badass mids and highs, but pretty much zero bass. Just have to put the sub in. And it looks totaly stock. You cant even tell I ever took the thing apart.
