gas probs!!!!
Old Aug 13, 2003 | 04:11 PM
99GSRbeerman's Avatar
99GSRbeerman
There is a speed limit?
Default gas probs!!!!
i have a 99 gsr and the only mods i have done to it is a true cold air intake and a performance muffler. i am only getting about 210 miles to the tank. i dont understand it. im wonderin if its the 2 15"s in the hatch? i have to drive 80 miles to school and back and 30 to work and back so needless to say my ass is spending about 45 week. way to damn much. what kind of mpg should i be getting and whats wrong?
Old Aug 13, 2003 | 09:19 PM
reno96teg's Avatar
how many gallons do you usually fill up with? what are your driving habits? do you hit VTEC a lot? do you tend to drive in low gears? need more info.
Old Aug 13, 2003 | 11:18 PM
patmnan015's Avatar
patmnan015
i get the same amount of gas mileage. if you're using the whole tank (I mean the WHOLE tank...people don't usually run it THAT low), then you're right, ur not gettin the right amount of mpg. but if you run it until u have about a quarter of a tank left, then fill it again, then u ARE gettin the amount of gas mileage that integras usually get. don't mean to rain on ur parade, but i end up spending anywhere from 40-60 dollars on gas a week as well, from work to home, from home to work, running around, etc.
Old Aug 14, 2003 | 05:07 AM
99GSRbeerman
i let the tank run low....like untill the light is on. i drive highway to tampa every day which is 80 miles from my house. the vtech i would say i use often. but i mainly cruise down to school.
Old Aug 14, 2003 | 05:10 AM
99GSRbeerman
i fill up 10 gallons....which is a full tank right?
Old Aug 14, 2003 | 07:53 AM
3 plus 1's Avatar
3 plus 1
13 gallon tank
And dont let it go below 1/4 of a tank. Its bad for the fuel pump
Old Aug 14, 2003 | 09:57 AM
GSRgranny's Avatar
GSRgranny
When i first got my GSR i would almost never get 200 mpg. But since i have to pay for gas and gas is going up where i live than i mostly just try to shift when the manual tells u too. Just cause im a cheep person. so my advise would dont drive it like a bat outta hell alot.
Old Aug 14, 2003 | 05:03 PM
reno96teg's Avatar
Originally posted by 3 plus 1
13 gallon tank
13.2 gallons, actually..
as far as going below the 1/4 mark, that may have been true decades ago, but it's no longer true today. and if you don't believe me.. i always fill up at 11-12+ gallons (that is well below the 1/4 mark), and have done so since i got the car (82k miles ago), and the fuel pump is still fine.
Old Aug 15, 2003 | 06:02 AM
Level_7's Avatar
Level_7
Note that the Integra's fuel gauge is graduated to read 'E' on level ground when there is exactly 10liters (2.6gallons) remaining (its a 50liter tank). Its sort of like a reserve tank for those of you who ride bikes. You should be getting 11km/L or more (about 25mpg+) if you drive conservatively. Given that, I don't think your 210 miles is not that bad, since you're only using about 75% of the tank.
Regarding the fuel pump, its not an issue with Integra's and most modern vehicles - just remember you have about 115km=70miles to drive after the 'E' before you're _actually_ empty.
Old Aug 18, 2003 | 05:23 AM
99GSRbeerman
so its safe to say that i am actually getting about 260 miles to the tank then right?..... i know there is also a differance in the gas station you use. around my house there is a 7-11, HESS, RACETRACK, MOBILE, and a CITGO. which has the best gas?
