Boost on gs-r stock internals
Old Aug 11, 2003 | 01:44 PM
mishima_beef's Avatar
mishima_beef
Default Boost on gs-r stock internals
is it ok to run 10 psi of boost on stock gs-r internals with upgraded fuel system and ignition system?
Old Aug 11, 2003 | 05:33 PM
B18C1TEG's Avatar
B18C1TEG
with tuning....yes. I personally wouldnt go ANY over ten on a stock block. I have a friend boosting 9psi daily on his First gen b16, and his cars running strong.
Old Aug 11, 2003 | 05:34 PM
mishima_beef
ok, and what tuning must be done?
Old Aug 11, 2003 | 05:40 PM
Snoopy's Avatar
Snoopy
been there done that
making sure you have enough fuel, and your ignition timing is correct.
Old Aug 11, 2003 | 05:41 PM
mishima_beef
so what do u guys recommend? hondata?
Old Aug 11, 2003 | 05:44 PM
Snoopy's Avatar
Snoopy
hondata is great for its price
Old Aug 11, 2003 | 05:49 PM
mishima_beef
so what hondata system should i look into for this setup ... 3b?
http://www.hondata.com/stage234.html
Old Aug 11, 2003 | 05:53 PM
Snoopy's Avatar
Snoopy
if you just want a plug and play system, get the s100 with boost option. if you want tunabitility, get the s200 with boost option. also, what year engine are you getting? try to get an obd1 year engine to avoid doing an obd2-obd1 swap. it also looks like there is a dealer/tuner in your area so maybe you should go talk to them and get more info.
Old Aug 11, 2003 | 05:57 PM
mishima_beef
hm the engine im getting is
B18C 94-00 (GSR)
ECU (P72)
is that OBD 2 or 1? and also why do i have to convert to OBD 1?
Old Aug 11, 2003 | 06:05 PM
Snoopy's Avatar
Snoopy
do you know the exact year engine you will be getting? hondata will only work with obd1 http://www.hondata.com/engines.html
