why do people put CTR pistons ect in their gsr's?
So will higher compression pistons give big gians in power on say my gsr? I keep reading about people with after market pistons with higher compression ratios but no one ever tells how big of a diff. in power they made.
When you up the CR its usually to help an already built motor run better. Higher compressions ratio for NA builds, lower for turbo. Thats general. I wouldnt suggest buying high CR pistons without other stuff already done (exaust, intake, cams, etc). And you'll need tuning. Otherwise if you tear the block down, replace them, and put it all back together without changing anything from stock, its gonna be a big waste of money.
Originally posted by Chrgsr96
I'm not stock though I have all of that. Figured pistons could possibly be the next step if they help out a lot.
