oil leak found
Old Aug 9, 2003 | 02:13 PM
twin3037's Avatar
twin3037
Default oil leak found
found out where my massive oil leak was finally i've been leaking a qaurt about every thousand and thoght i had a bad seal or somthing but it's acctually the oil filter pan on this item i am tolotally clueless is it easy to replace expensive or what any help or refrences would be greatlly appreciated
Old Aug 9, 2003 | 02:39 PM
Spec R's Avatar
Spec R
i dont get what you're saying. oil filter pan? wheres that?
who found the leak? you or someone else?
DB Squad
Integra Forum Moderator
Old Aug 9, 2003 | 02:52 PM
twin3037's Avatar
twin3037
the dealrship did when they were replacing my brake rotors they said it was the oil filter pan but didn't say how much that owuld cost to fix
Old Aug 9, 2003 | 03:20 PM
Kai's Avatar
Kai
Rotorphile.
I've heard of an Oil Filter.
I've heard of an Oil Pan.
...but never an Oil Filter Pan.
It is probably the oil pan gasket like I suggested in your other thread. It's not very hard to replace... it's about as easy as changing brake rotors
Old Aug 9, 2003 | 07:51 PM
twin3037's Avatar
twin3037
hahah man i would change all the stuff on my car cept oil bc i have no where to put taht after draining it but it's not my car and my parents think the pros are better which is true but i could have a hellaha lot of fun doing it
Old Aug 9, 2003 | 07:56 PM
pdooley's Avatar
pdooley
wow, thats all just wow.
Old Aug 10, 2003 | 08:50 AM
reno96teg's Avatar
please, there's no need for comments..
twin3037, can you find out exactly what the dealer said was leaking, and if he did indeed say "oil filter pan"?
Old Aug 10, 2003 | 10:35 AM
twin3037's Avatar
twin3037
well after checking wiht the paretns bc i was at work and they were they fixing it my mom says that they said it was the oil filter pan. but after talkign to my dad he says taht they acctually said it was the seal around the oil filter or the oil pan one or the other. mothers don't knwo nething about cars
Old Aug 10, 2003 | 10:40 AM
qtiger's Avatar
qtiger
If it's the oil pan gasket, a monkey could change it. No problem.
If it's the O-ring on the oil filter... well, that speaks for itself.
Old Aug 10, 2003 | 11:37 AM
twin3037's Avatar
twin3037
do you know where i can get an oil pan gasket? and how much is it
