90-93 JDM one piece headlights weird glow??
Old Aug 8, 2003 | 08:59 PM
JTegLS's Avatar
JTegLS
Default 90-93 JDM one piece headlights weird glow??
ok i just installed the JDM one piece headlights and now when i have my headlights on the blue brights indicator light "glows" but it does not actually turn on. it will still turn on when i turn the brights on but it never used to glow like that before. i was wondering if anyone else has had this prob or if anyone has any ideas of what it could be??
thanks
Old Aug 9, 2003 | 12:29 AM
lunthuG's Avatar
lunthuG
I had that same problem in my VR6, do you have any aftermarkte bulbs installed? That was my problem I'm guessing the wireharness couldn't handle the higher wattage bulb, I removed them and the high beam glow turned off. Hope it helps.
Old Aug 9, 2003 | 07:14 AM
JTegLS's Avatar
JTegLS
well the bulbs cam in the headlights so im not sure, they seem the usually yellow lights. i just hope i did not wire them up wrong but i cant find a good wiring diagram anywhere
Old Aug 9, 2003 | 03:37 PM
Kai's Avatar
Kai
Rotorphile.
You probably crossed a wire somewhere or didn't fully insulate them. How did you splice/insulate them?
Oh, and BTW, the JDM 90-93s use a yellow lense inside the fog section, not a yellow bulb :thumbup:
Old Aug 9, 2003 | 10:48 PM
JTegLS's Avatar
JTegLS
well i used these little connectors that u can buy at walmart but i think ur right with the crossed wire, do you know what color connects to what, i tried using the thing on www.g2ic.com but its diff than what mine are. (colors) if u have an idea it would help thanks!
Old Aug 9, 2003 | 11:33 PM
Kai's Avatar
Kai
Rotorphile.
Unfortunately my 'teg didn't live long enough to get one-peice headlights.
Did your lights come with the wire harness? I thought it plugged right up to the USDM main harness. :dunno:
Old Aug 10, 2003 | 06:09 AM
JTegLS's Avatar
JTegLS
no the JDM harness is diff cuz the new bulbs are h4 and the stock bulbs are 9004, i just was wondering if anyone had a good wiring diagram or had knew the order so i could see if i wired them right i dont want them to melt
