Installing A Strut Bar?
Old Jul 18, 2003 | 09:03 AM
IamNemo's Avatar
IamNemo
You know me...
Default putting a strut bar on?
Ok...I'm gonna sound like a moron, but when putting a strut bar on do you just take the nuts off of the strut, put the bar on and put the nuts back on...and then do the same to the other side? I just don't want to screw anything up So I'm trying to be extra careful.
Old Jul 18, 2003 | 11:39 AM
whoaitslen2's Avatar
whoaitslen2
hermit
yeaup
Old Jul 18, 2003 | 02:12 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
you might have to jack the car up if the bolts are hard to remove, and don't line up.
Old Jul 18, 2003 | 11:27 PM
b00gers's Avatar
b00gers
yes. its that simple. good luck.
Old Sep 4, 2003 | 09:12 PM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Shouldnt the nuts be torqued???
Old Sep 5, 2003 | 09:10 PM
Technodigifreak's Avatar
Technodigifreak
Hot-Modder
yeah its that stupid simple, and as far as i know there is no torque specified for the nuts on the strut mount
Old Sep 7, 2003 | 05:01 PM
johnnybravo's Avatar
johnnybravo
Default Jacked up....
Would too much tension be put on the strut bars if you lift the car on a jack and then apply the bar? I mean lifting it up would release tension long enough for the application sure, however when the car is back on ground it would have to handle a lot of stress not to mention performance driving? Best explanation......
Old Sep 9, 2003 | 05:33 AM
Civic Type Sev's Avatar
Civic Type Sev
If you decide to jack up the car for installation... it will relieve the stress on the frame and then when you lower it again with the bar; the bar will be pre-compressed which will make your car even stiffer. That's what I did when I installed mine.
Note that for this to work you have to jack up the car from the centerline and this can be quite unstable. If you decide to not jack up the car from the centerline and use the regular lifting points on the sides you might as well not lift it up at all since the frame will still be loaded.
Hope this helps.
Old Sep 9, 2003 | 10:08 AM
IamNemo's Avatar
IamNemo
You know me...
Considering I put the strut bar on around....oh.....2 months ago...I was just wondering why people were still replying to this post!
Old Sep 13, 2003 | 02:06 AM
Big Chaze's Avatar
Big Chaze
Mr Clutch
Cause I came across this thread, and I asked if the nuts had to be torqued.
ISnt that what the search tab is for???
