Valve cover gasket Accord 94 qt?
Old Jun 24, 2003 | 08:30 AM
miaminikko's Avatar
miaminikko
Default Valve cover gasket Accord 94 qt?
Hi,
Ive replaced my valve cover gasket and grommets after a valve adjustment
can anyone tell me where the round O- ring gaskets go?
please see the attached pic.
thanks
File Type: jpg
Old Jun 24, 2003 | 10:44 AM
silverstreakin's Avatar
silverstreakin
TRD japan ownerages
plug holes?
Old Jun 24, 2003 | 10:45 AM
crxb16er's Avatar
crxb16er
the top of the spark plug holes, under the bigger black gaskets, check out the top of ur valve cover and they lay in there, just make sure u remove all the old gasket material first, this is how it is on my rex neway. good luck. and be sure to use just enough rtv silicon when putting it all together especially in the corners.
Old Jun 25, 2003 | 07:48 AM
miaminikko's Avatar
miaminikko
Hi,
Thanks for the answer,
My O ring is missing thats why I have no idea hwre it goes.
so to recap.
I have the cylinder head, then the spark plug tube
opening in it , I put the Oring on the tube opening, and the larger rubber gasket goes on top of that (the larger rubber gasket has a lip and sits in the valve cover, I know)
right?
thanks
Old Jun 25, 2003 | 07:59 AM
crxb16er's Avatar
crxb16er
yeppers, oh wait, actually the smaller oring lays on top of the bigger rubber gasket, the smaller oring should have an inlay on the valve cover that it goes into, on top of the bigger rubber gaskets, the big guys u just lay some rtv silicon under and on top of just a little bit mind u and then u bolt it all down to create a good seal so u dont leak oil into the spark plug hole. its very easy to do.
