Civic LX 03 Daytime Running Lights - HELP
Old Jun 23, 2003 | 11:51 PM
alexmcohen's Avatar
alexmcohen
Default Civic LX 03 Daytime Running Lights - HELP
Hi:
I have a Honda Civic LX 2003 and it comes with Daytime Running Lights enabled.
My questions are:
1.- Is it possible to switch this role from the high-beam lights to the parking lights? How?
2.- If the above is not possible, then how do I disable Daytime Running Lights?
Thank you.
Old Jun 24, 2003 | 11:09 AM
crxb16er's Avatar
crxb16er
check the fuses under the dash and see what they go to otherwise ur gonna need to buy a haynes helms or chiltons with wiring diagrams on ur particular make and model and do some rewiring. its completely possible just requires some work, and a good diagram of how the wiring is all hooked up.
Old Jun 24, 2003 | 03:33 PM
alexmcohen's Avatar
alexmcohen
Thanks, I'll take a look under the dash and see what I find.
Old Jun 25, 2003 | 01:58 PM
alexmcohen's Avatar
alexmcohen
All the cars at the dealership where I got my car at, had DRL installed. I looked at the fuse diagram in the manual, and there are two fuses labeled DRL *canadian models only. I removed both fuses but it didnt work at all, the lights were still on, so I just wonder what the hell did they do with that. My concern is because I replaced the stock halogen bulbs with XENON bulbs, which are known to have a limited life.
Any ideas welcome, thanks alot to the ones that are trying to help me already.
Old Jun 25, 2003 | 02:00 PM
alexmcohen's Avatar
alexmcohen
I'm having a hard time trying to figure out where the fuses under the dash go to and haven't found yet a repair manual for the 2003 models.
Old Apr 6, 2004 | 03:00 PM
rklawson's Avatar
rklawson
2000 Electric Blue Civic
you try the drl relay. Itook mine out on a 2000 Civic CX and that worked fine
