Fuel Pump Fuse
I need someone to let me know where the fuel pump fuse is? I'm sure its easy to find, but I can't figure it out. I can't find it in the fuse box inside the car and I can't find it in the fuse box in the engien bay?? Where is this thing at? I'm changing my fuel filter, and I want to get all of the fuel out of the lines. Someone help me out. Thanks
just unplug the ecu fuse under the hood, that will disable the pump. Then just loosen the 12mm nut on the top of the fuel filter and let the pressure out. You will get some spillage but not any to speak of
Yea I just ended up taking it out with out pulling a fuse or anything, but had a towel wrapped around the lines. There was very very minimal spillage. I also took off the gas cap cause someone had told me that that takes some pressure out of the lines. Thanks :thumbup:
