Integra pcv valve
Help... My non-vtec 98 integra has the pcv valve coming out the valve cover, venting to the intake manf. I picked up nice v. cover from a 95 teg that fits, but there's no hole for the pcv valve. It seems from 94-97 Honda had something called a breather box between the pcv valve and the intake manifold. I need to make this valve cover work! Can I relocate my pcv valve? To where?
check out www.theoldone.com they have a modified breather system or somthing they may be able to help you.
Thanks, that site has a moroso thingme that might work. I need to know where the pcv goes on a 94-97 teg: in the head under the intake manf?? If so, was the opening simply plugged when they started putting the pcv in the v. cover in later model years?
My '95 GS-R pcv valve is on the breather box on the back of the block. Under the intake manifold.
The breather tube from the valve cover is supposed to draw air into the engine from the intake tube before the throttle body.
