What is the white tank between the right fender and inner fender for?
Old May 30, 2011 | 06:30 AM
Ronaldo's Avatar
Ronaldo
Default What is the white tank between the right fender and inner fender for?
My son lost the right inner fender on his car and now I see a white tank. It is empty I know the one on the left side (drivers side) is for window washing fluid. What does this one do?
It passes to the engine compartment through a black rubber gromment but appears to be open. In other words, the white plastic tank has a neck that presses up against the black rubber but doesn/t extend pass it.
When I look from the engine side it looks like a oval cut out with nothing covering the opening.
Old May 31, 2011 | 02:32 PM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Does the car still has the stock air box? If so, it is part of that system.
Old May 31, 2011 | 03:50 PM
Ronaldo's Avatar
Ronaldo
Default I guess that it catches the water that get sucked into the intake system
and then it sets there until it evaporates?
Old Jun 1, 2011 | 10:08 PM
Spec R's Avatar
Spec R
its to cancel out the resonance (sound) of the air intake.
DB Squad
Integra Forum Moderator
