New system thinking bout...what do u guys think?
Old Jun 11, 2003 | 03:47 PM
Jedman784's Avatar
Jedman784
Default New system thinking bout...what do u guys think?
Hi...i have a 94 integra hatchback. Im lookin to put in a new Kenwood eXcelon KDC-X569 head unit with 4 Type R alpine spr-174A 6.5's speakers. Also the alpine mrd-m300 mono amp with the type R's SBR-102CR 10" Subwoofer preloaded in the box. What do you guys think? Should i not get the subs already in the box??? Lemme know about everything. Thanks alot. Not really that educated on alot of this stuff.
Josh
SPECS
Speakers
160W Peak Power
40W RMS
Frequency Response: 45Hz 30kHz
1" Soft Dome Tweeter with 15° Swivel Capability
In-Line 12dB HP Crossover with Tweeter Protection
Aluminum Coated Poly Cone
Cast Aluminum Woofer Frame
Compound Reflex Design
Dual Terminal Cap
Flared Vent
Low Tuning Frequency
MDF Enclosure Construction
Phase Aligned Exterior Vent
Preloaded with SWR-1041D
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
amp
150 watts RMS x 1 at 4 ohms
300 watts RMS x 1 at 2 ohms
MOSFET power supply and output stage
STAR Topology for cleaner sound
Bass Engine® features:
Low-pass digital crossover, 30-200 Hz, 24 dB/octave
Variable subsonic filter (15-50 Hz in 5 Hz steps)
Parametric EQ variable from 30-160 Hz
Bass Compensator enhances low-end definition
Top-mounted digital control center with cover
Time correction 0-10 milliseconds in 0.5ms steps
Phase correction 0-180° selectable
Digital readout
Detachable front cover
Blue power LED
Delayed turn-on
Speaker- and preamp-level inputs
Gold-plated terminals
8-5/16"W x 2-11/16"H x 11-½"D (10"D without front cover)
Old Jun 13, 2003 | 04:11 AM
Randy12vp's Avatar
Randy12vp
Seems like a decent setup.
Old Jun 13, 2003 | 04:22 AM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
just make sure the box construction is indeed MDF and not particle board. The setup looks to be good. ALpine type Rs are good. You'll enjoy you're setup.
Old Jun 13, 2003 | 09:21 AM
Jedman784's Avatar
Jedman784
thanx alot guys
