Stuck in Drive
Old Jun 11, 2003 | 03:23 PM
hodgins's Avatar
hodgins
Default Stuck in Drive
I have a 92 automatic integra. I turned on my car
this morning and it's basically stuck in drive no matter
which gear I select (park, reverse, neutral, drive).
I almost smashed into my girlfriend's car parked right
in front of me, when I put the gear in reverse and
hit the gas!!! very weird.
Any ideas on what the problem is? I hope I don't
have to replace the transmission .....
Old Jun 11, 2003 | 03:45 PM
LT's Avatar
LT
The deer had to die!
most automatic transmissions are equipped with a solenoid that locks the transmission. This solenoid may have gone bad.
My friends old auto cavalier wouldn't disengage out of overdrive. When we got back to his house, his dad just pulled the harness off the solenoid (on the transmission) and it worked normally again.
I'll try and locate it for you.
Old Jun 11, 2003 | 03:56 PM
LT's Avatar
LT
#6 is the Lock-up Solenoid, disconnect that. (#4 is the shift solenoid - don't disconnect that)
Old Jun 23, 2003 | 09:30 AM
hodgins's Avatar
hodgins
Took it into the shop, turns out the
transmission gear shift cable needed
to be replaced. Cost about 250$ (canadian)
for the part.
Old Jun 23, 2003 | 09:33 AM
BonzoAPD's Avatar
BonzoAPD
that sucks but atleast it works now.
Old Jun 23, 2003 | 10:06 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
You need a 5 speed bro!
Old Jun 23, 2003 | 10:23 AM
teg_fan's Avatar
teg_fan
I like integra's
:yay:
Old Jul 16, 2003 | 01:28 PM
95AccordEXR's Avatar
95AccordEXR
exact same thing happened to my mother in law's car yesterday. the cable seized in the line and when I moved the shifter the line broke. The acura dealer want's $260 for it
