JDM TypeR Transaxle conversion
Old Jun 10, 2003 | 10:47 AM
Oldkid's Avatar
Oldkid
Default JDM TypeR Transaxle conversion
Hello all knowing ones. I have a tech question for you. I recently aquired a JDM Type R transaxle. My daughter and I have a pretty serious LS project car going. I was just thinking....(problem for sure)....are the LS axle stubs the same size as the Type R? I know the outers are bigger and also of course 5 lug but I need to know if the LS stubs will fit the Type R LSD. Obviously I can throw the caliper on the axles myself but you folks I'm sure know the answer much quicker.
Thanks for your time!
Old Jun 12, 2003 | 09:04 PM
swtprelude's Avatar
swtprelude
so are you asking if the outer axle fit the LS hub? if thats ur question than no. JDM axles are bigger there 36mm i believe. US version is 32mm. and yes the Ls axle will fit the type r LSD.
Old Jun 12, 2003 | 09:13 PM
Oldkid's Avatar
Oldkid
From the info I have gathered that was my understanding too. Thank you for the reply!
Old Feb 10, 2007 | 03:38 PM
ctr93's Avatar
ctr93
i have a set of jdm 5 lug conversion myself.. the ponly problem is that i dont have the axles.. and i know that i have to use the 36mm set.. .but i heard that it could be possible to use the cr-v axle!! just curious to see if any out there knows thanx,... geovannie_017@hotmail.com
Old Feb 10, 2007 | 03:40 PM
Snoopy's Avatar
Snoopy
been there done that
as long as you keep the 4 lug hubs you should be able to use regular ls axles
