70k miles now what?
Old Jun 10, 2003 | 02:05 AM
strykernyc's Avatar
strykernyc
Default 70k miles now what?
i just reach the 70k miles what are the regular stuff parts that i'm supposed to change/replace, so far i have only change the brakes and oxygen sensors which is like every 60k since new heh now i'm thinking belts, water pump anything else because i wanna do all at once, and lately when i turn off the car there is this little black thing i can read what is says to gas tank it makes noise like if it had a fan inside spinning goes for seconds again then again then goes away i wonder what it is i will take pics to be more specific thanks. accord ex 96 vtech
Old Jun 10, 2003 | 05:37 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
change all belts, water pump and seals, also do the regular tune up which is spark plugs, distributor cap, distributor rotor, pcv valve, fuel filter and air filter and you should be good to go.
Old Jun 10, 2003 | 05:50 AM
decibel_dj's Avatar
decibel_dj
basically what was said.
you might want to check, change or rotate your tires
Old Jun 10, 2003 | 06:50 AM
vtecaccord01
when did you buy the car and how many miles was on it?
Old Jun 10, 2003 | 07:02 AM
decibel_dj's Avatar
decibel_dj
damn my car doesnt feel like its broke in yet and i'm in the low 70k's but then again most of my car has be swapped out in the years i've owned it. you should be fine,
Old Jun 10, 2003 | 07:20 AM
decibel_dj's Avatar
decibel_dj
your car is fine.. my car needs a "blessing" to save her from the junk yard's crusher
Old Jun 10, 2003 | 09:15 AM
jschmid's Avatar
jschmid
tranny fluid, coolant as well if you haven't kept up with regular scheduled maintaince.
Old Jun 10, 2003 | 12:33 PM
DJ Scotty's Avatar
DJ Scotty
What do you mean, Decibel? 70K doesnt sound like a lot for a Honda, from what I hear...especially one that wasnt made in the States...
Old Jun 10, 2003 | 12:34 PM
DJ Scotty's Avatar
DJ Scotty
VTEC,
I picked her up on Halloween of 1998 as an early 1999 model, and she had 100 miles on her because the dealership had to get her from another dealer in upstate New York...
Old Jun 23, 2003 | 10:52 AM
EdyJun's Avatar
EdyJun
I have a ? where is the PCV and how much to change?
