Help
Old Jun 9, 2003 | 05:02 PM
brian1122's Avatar
brian1122
Default Help
Hello
90 Integra 4 Door
I have no breaks. How I know this is... well... plain and simple, I can't stop, the pedal has top be jammed all the way to the floor, and then it only brings the car to a rolling stop. Here's a break down of what I've replaced... Master Cylinder (spelling), Proportioning Valve, Font Right Metal Line from Prop. Valve to Rubber Break line, and all brake fluid and still no fluid/pressure going to the Front Right or Rear left side.
The Front Left and Rigth Rear calipers are getting pressure, I know this becuase I touched the rotors and burnt my finger tips. But the Front Rright and Left Rear aren't getting pressure at all. None of the lines are bent or crushed, not are they corroded, there is a little bit of fuild that spurts out of the Front Rright, maybe a 1/10 of a teaspoon if that, which is dark in color. Could it be the Booster, or something.
If anyone knows anything or can gfive me some advice please do so. I plain in replacing the Booster either tonight or tomorrow... Someone Help
Old Jun 9, 2003 | 05:10 PM
XSrcing's Avatar
XSrcing
if their is fluid coming out of the caliper, then your piston seals are shot.
