6th gen accord tranny swap
i did a search on this, and most ppl are saying that it's possible to swap the current tranny w/ 5 speed or 6 speeds from other cars. But, wouldn't there be a problem since the j30 only has 4 speeds? oR, would the swap just change the whole setup? ..just curious..
also, i heard from someone else that a swap from an Acura Legend is possible. I bet this would be a lot easier to find and a lot cheaper too. :naughty:
If you have the V6, you can use the CL Type-S 6 speed or the Accord Coupe V6 6 speed. The Legend swap is not a bolt on and requires some work if it can, in fact, be done.
Obviously the number of gears wouldn't matter, as you're replacing the entire transmission with a new one.
Originally posted by dscx628
cool. is there any fabrication needed for this swap? or possible for a DIY?
i have access to a lift and the guy there has a hell of a lot of experience so he can help me out.
so, there's nothing that needs to be altered? like the ECU? and what about the clutch pedal itself? would it be included w/ the tranny?
thanks for your help.
The CL Type-S transmission has a Limited Slip Differential, so you should lean towards that.
Keep us updated man, and good luck :thumbup:
Chris
Originally Posted by youreviltwin
Legend trans sit like a rwd. It would take a lot of fabricating.
I have an 00 accord SC with an 03 cls 6spd in it. The ecu is not a simple thing to deal with.
