please help with 94-97 accord
Old Jun 6, 2003 | 09:25 AM
jem7vwh's Avatar
jem7vwh
Default please help with 94-97 accord
I've got a replacement grille molding, but I need instructions on removing the grille. I've seen other people's DIY posts where they removed the grille without taking off the bumper. How do I do this?
Old Jun 6, 2003 | 09:53 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
are you refering to the upper grill?
Old Jun 6, 2003 | 10:11 AM
aux's Avatar
aux
More Black on Black Crime
pop the hood and remove all the visible screws. theres one on the bottom too as well as tabs on each side.. use a screw driver to press the tabs down and pull
Old Jun 6, 2003 | 12:22 PM
jem7vwh's Avatar
jem7vwh
yes I was referring to the upper grille
Old Jun 6, 2003 | 01:26 PM
EliteAccord's Avatar
EliteAccord
Banned
Pop open your hood and remove the 4 philips button head screw on top.
Old Jun 6, 2003 | 01:42 PM
b_dyche's Avatar
b_dyche
owned by a 9 car pile-up
and be gentle... it sucks when you have broken pieces to try and re-assemble...
Old Jun 6, 2003 | 02:14 PM
jem7vwh's Avatar
jem7vwh
the screw on the bottom, is that the one near the hood latch?
Old Jun 6, 2003 | 02:49 PM
Samson's Avatar
Samson
chris is the devil
well its easily seen... every screw that u see attatched to the grill comes off..... Its lower and in the back.
Old Jun 7, 2003 | 08:47 AM
95AccordEXR's Avatar
95AccordEXR
5 screws, four easily seen but the on in the middle is down inside the grill. Then, using a screwdriver, press in on the plastic retainer clip on each side. pull it out.
Old Jun 7, 2003 | 04:50 PM
accordtuner's Avatar
accordtuner
Banned
its called the "search" button. click on it.:fawk:
