What do I need to hook up a TV Screen in my teg?
Old May 28, 2003 | 07:25 AM
BonzoAPD's Avatar
BonzoAPD
Default What do I need to hook up a TV Screen in my teg?
I am buying a 5 1/4 inch screen. What do I need to get to hook it up?
Also is there anything I can do to hook it up to a cd player and get it to be a display for the cd player?
Old May 28, 2003 | 11:07 PM
acuradriva's Avatar
acuradriva
you need a dvd player, and a h/u that has an aux input would be the best/easiest way to do it. and possiblly a power inverter depending on what kind of dvd player you get.
Old Jun 3, 2003 | 05:43 PM
BonzoAPD's Avatar
BonzoAPD
anything else? How do I power the DVD player?
Old Jun 3, 2003 | 08:28 PM
acuradriva's Avatar
acuradriva
is it an indash? or a house dvd player. If its one that goes in a house you need a 115V power source so you need a power inverter.
Old Jun 4, 2003 | 09:13 AM
BonzoAPD's Avatar
BonzoAPD
where can I find a power inverter? How much do they run? Are they hard to install?
Old Jun 4, 2003 | 12:20 PM
barto's Avatar
barto
Target, Walmart, Miejer ect will have an inverter. You only need it if you are using a home dvd player, but they totally shut off when the car is off, so you lose your spot. You might want to purchase a car DVD player so that you don't lose your spot, cuz that sucks when crusin round town.
I have an Xbox in my car, but I can deal with the inverter.
Old Jun 5, 2003 | 06:37 AM
BonzoAPD's Avatar
BonzoAPD
Can you post your setup? I am trying to get ideas of where I can install these items. Pics would help. Thanks.
Old Jun 5, 2003 | 11:03 PM
cascivic's Avatar
cascivic
i have my inverter wired from the battery throught he dash throuhg center console and it sits underneath the seat facing backwards. then i have the ps2 facing forward so it ejects out the front.
Old Jun 6, 2003 | 05:06 PM
acuradriva's Avatar
acuradriva
Here's my set up i have the inverter mounted under the false floor. I just grounded it in the trunk and hooked up the power to the wire on the back of the cig lighter so it only comes on when the ignition is on.
Old Jun 12, 2003 | 11:36 AM
BonzoAPD's Avatar
BonzoAPD
the pic doesn't work, can you try to post it again? Thanks.
