shocks question...
Old May 24, 2003 | 11:07 PM
b00gers's Avatar
b00gers
Default shocks question...
asking specifically about the KYB AGXs, when you buy aftermarket shocks, are they designed so that the area where the spring sits is the same height as the stock shocks?
such as: if i have stock shocks with, lets say, HR OEM springs. will the setup yeild a lower ride height if i mated those springs with an aftermarket shock?
i know the koni yellows have adjustable perches, but what about the shocks that dont.
kinda hard to word the question, you get my drift? thanks.
Old May 25, 2003 | 01:07 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
So basically you're asking if the spring perches on KYB AGXs are in the same spot relative to the stock shocks. They are.
If you put stock springs on KYB AGXs, then you will get stock ride height.
Old May 25, 2003 | 01:23 PM
b00gers's Avatar
b00gers
thanks.
