engine rebuilding tips
Old May 23, 2003 | 09:20 AM
9600baud's Avatar
9600baud
JDM rox ur world
Default engine rebuilding tips
My teg's got a leaky head gasket so i'll have to replace it sometime. But when i do that, while they're in there, anything else I should replace that might be worn out and not as smooth anymore? ie pistons, rods, other seals, etc... thanks for reading, or maybe some suggestion on better parts? its a 94 LS
Old May 23, 2003 | 03:44 PM
XSrcing's Avatar
XSrcing
ummm...to replace the pistons and rods you have to remove the entire engine, not just the head.
but you could have the valve seals replaced.
Old May 24, 2003 | 01:24 PM
Level_7's Avatar
Level_7
Also check out the Hayes Manual or some other since typically during a particular repair section, they list items that should be done at the same time or problem areas to inspect.
Old May 24, 2003 | 01:44 PM
GRAYGHOST's Avatar
GRAYGHOST
replacing the headgasket... u can get cams, camgears, port the head, valves, val springs, val seals, port intake mani, if your going to take off the timing belt u might want to replace the waterpump.
