ABS compressor cycle's on and off
Old May 22, 2003 | 05:05 PM
TeggerLS's Avatar
TeggerLS
Default ABS compressor cycle's on and off
How do I fix this, I already pulled the relay to keep it from trying to pressurize. I'm guessing it has something to do w/ that gold tube on the ABS??? I think I read a thread a while ago about the O-ring going bad.
Anyone know what's wrong and if I'm right can I do the work w/o any trouble's safety risks???
I'm quite capable of mechanical work
Old May 23, 2003 | 08:55 AM
JimBlake's Avatar
JimBlake
Default Re: ABS compressor cycle's on and off
Originally posted by TeggerLS
... I'm quite capable of mechanical work
Get a Helm manual for your car. It has a section about replacing the accumulator (that 'gold tube'). It sounds like that's the problem. You do have to relieve the pressure so you don't hurt yourself. If I try to simplify the procedure here, I'll probably leave out something important. You'll have to bleed the ABS after, probably have to bleed the main brakes too.
If it cycles on & off fast enough, it'll set off the ABS idiot light. If that hasn't happened, then maybe it's not really bad?
Old May 23, 2003 | 09:39 AM
TeggerLS's Avatar
TeggerLS
Default Re: Re: ABS compressor cycle's on and off
It turned the ABS light on a long time ago, that's why I pulled the relay. As for depressurizing it...how do I go about this? I'm selling the car so I can't see a point in spending $60-70 on a Helms manual. Worse come's to worse I'll bring it to acura...oh well.
