Type R header
Old May 21, 2003 | 07:01 AM
slkstr2's Avatar
slkstr2
Default Type R header
Is it true that JDM Type R header only come in 4-1?
I just had a JDM Type R motor swap done and a 4-2-1 header came w/ it. I was later told by another person that the header I received was a CTR header. Could this be true?
Also, is 4-1 made for high gains while 4-2-1 is made for low gains?
Old May 21, 2003 | 07:07 AM
ur31337's Avatar
ur31337
Colby
That's a pretty general question. It really depends on WHICH 4-2-1, honestly. The TODA 4-2-1 makes power EVERYWHERE, as do many others.
I don't know enough about the CTR header to tell you either way, but the JDM ITR is a 4-1 w/ a 2.5" collector.
Old May 21, 2003 | 07:13 AM
slkstr2's Avatar
slkstr2
Say we're comparing a DC JDM 4-2-1 to a DC JDM 4-1. Which will give me more low gains, high gains, etc?
Old May 21, 2003 | 10:54 AM
all stock's Avatar
all stock
4-2-1 low gains, 4-1 high gains.
Old May 21, 2003 | 03:06 PM
Snoopy's Avatar
Snoopy
been there done that
um i dont think DC makes a JDM 4-2-1
Old May 22, 2003 | 07:00 PM
2000-R's Avatar
2000-R
so if i get the DC Sports JDM 4-1 header w/2.5in collector...do i really have to get a 2.5 cat and 2.5 piping all the way??if not...any other choose??
Old May 22, 2003 | 07:28 PM
Snoopy's Avatar
Snoopy
you'd have to at least get the 2.5 inlet on the cat to make it all fit. its up to you if you want 2.5 all the way through.
Old May 22, 2003 | 07:49 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
A 4-2-1 header will give more gains in the mid range and the 4-1 will give more gains in the top of the RPM range.
I am not sure if there was a JDM 4-2-1 ITR header or if the CTR header was 4-2-1. If the CTR header was 4-2-1 then I would make sure the engine you got wasa 1.8L and not the CTR 1.6L...and don't just look at the tranny stamp because they coulda swapped the tranny.
Old May 30, 2003 | 09:05 PM
spooncivicb16b's Avatar
spooncivicb16b
whats your engine code? and if you have a typ r motor i would go with 4-1 header because it makes like all its power in high rpms any way
Old May 30, 2003 | 10:36 PM
Capt. Type R's Avatar
Capt. Type R
At some point i'd like to get Spoon's header, but it's a lot of money. It's a great header. The design and make of it was thought out and tested very well. Plus it's Spoon, anything Spoon is good. heh.
