Crank Bolt Removal
Old May 16, 2003 | 03:50 AM
mhoops's Avatar
mhoops
Default Crank Bolt Removal
This may sound like a dumb question, but does the crank bolt on a 1994 Acura Integra RS turn clockwise or counter clockwise to loosen. A local machanic told me the bolt is probably reverse threaded. But nothing I have found online tells me for sure. Any help would be greatly appreciated.
Old May 16, 2003 | 09:47 AM
qtiger's Avatar
qtiger
Normal threads.
Hope you have the pulley tool.
Old May 16, 2003 | 01:39 PM
mhoops's Avatar
mhoops
I don't have the tool yet. Hopefully I will for the weekend. Is it a normal threaded bolt? Or is it reverse threaded?
Old May 16, 2003 | 02:57 PM
XSrcing's Avatar
XSrcing
normal thread. and it will most likely take an impact to get it off.
Old May 17, 2003 | 05:20 AM
mhoops's Avatar
mhoops
Thanks. I have tried an air gun, but the thing will not budge. It could be because I only habe a small air tank.
Old May 17, 2003 | 06:49 AM
90'RS's Avatar
90'RS
Try using a penetrating oil such as PB Blaster and see if that helps to bust it loose.
Old May 17, 2003 | 10:54 AM
XSrcing's Avatar
XSrcing
i took one off of a BMW 5.0L V8 once, and it took 5 minutes of constant pressure with a 1/2 inch impact to even get it to budge. and this was after letting it soak in PB blaster for an hour.
Old May 17, 2003 | 11:46 AM
Dutin's Avatar
Dutin
It takes the tool and a long impact wrench with a ton of force!!!
Old May 19, 2003 | 04:30 PM
MikeR's Avatar
MikeR
just battled this monster and even with the tool i dont think i could do any good, tried a pipe wrench around the pully and it held but i couldn't put enough booty behind it to break it loose, i eventually had a 3/4" air wrench with 170 psi which still had a hell of a time to break it free, good luck. i finaly got short sudden bursts of psi on the air gun that finally brought it out just before i burned the car to the ground from frustration!!!
