1990 Acura Intergra RPM Too High
Old May 13, 2003 | 01:48 PM
kalipinoiryder's Avatar
kalipinoiryder
Default 1990 Acura Intergra RPM Too High
i have a 92' integra, the rpm is too high.. it is about 1500, i try to adjust the idle control but does not work, replaced the Air Control Valve, but still no avail.. anyone plese help.
Old May 13, 2003 | 02:24 PM
RB's Avatar
RB
snitches get stitches
www.g2ic.com
go to teg tips, or the help forum.
Old May 13, 2003 | 03:50 PM
coletrain25's Avatar
coletrain25
Are your RPMs that high right after you start up or is it after the car sits idling for a while?
If you just started your car, its normal for the RPMs to be that high, but if they are still that high if the car is idling for a while then you should check out the link RB posted.
Old May 14, 2003 | 03:25 PM
ambition's Avatar
ambition
StillDPG
check your vaccum lines for leaks and cracks
Old May 15, 2003 | 05:42 PM
kalipinoiryder
Default 92 integra RPM Too High
my RPM are high whne hot, even higher when cold, when hot it is on 1500, hwne it is cold goes all the way up to 3300,
Old May 16, 2003 | 11:25 AM
brian1122's Avatar
brian1122
check your TPS... could be bad man...
