Check engine light
Old May 13, 2003 | 05:28 AM
mitch48's Avatar
mitch48
Default Check engine light
My daughter's 2001 Integra has the check engine light on. A local shop reset it but couldn't pull the code to see what the problem was. I'm totally new to Acuras, so please bear with me. I've been told it is a common occurance and can mean any one of a number of things. If anyone can direct me to a site that shows how to pull the code I'd be grateful, or for any other helpful info on this topic.
Old May 13, 2003 | 05:55 AM
reno96teg's Avatar
here are instructions on pulling the code:
http://www.bseries.net/html/garage/engcode.php
this may be a dumb question, and i hope i'm not insulting your intelligence, but could it have been the maintenance required light, and not the check engine light? i've noticed people confuse the two on a few occasions.
good luck.
Old May 13, 2003 | 06:37 AM
mitch48's Avatar
mitch48
Its a little yellow light in the left side of the instrument pod that says "CEL". I've been told (and the manual reinforces this) that it is a check engine light. Where is the "maintenance required" light?
Old May 13, 2003 | 08:06 AM
reno96teg's Avatar
the maint req'd light is below and between the temperature gauge and tachometer. but i just wanted to make sure.
has the CEL come back since the shop reset it?
Old May 13, 2003 | 08:48 AM
mitch48's Avatar
mitch48
Default CEL light
Yep, it took less than an hour's driving for it to come back on.
Old May 13, 2003 | 08:52 AM
reno96teg's Avatar
pull the code and tell us what you get.
Old Jun 2, 2003 | 07:27 AM
mitch48's Avatar
mitch48
Default CEL code is:
I had Autozone pull the code on my 2001 Integra and it came up P1457, which they said is a dealer code they cannot read.
What is up?
