camberkit ...when!?>
Old May 11, 2003 | 03:28 PM
cu3tip's Avatar
cu3tip
Default camberkit ...when!?>
hey guys i just got my rims on, i got the tenzo shu-4 in gunmetal with polished lip
205/40/17
i need to know how long i can run these tires before iwill start to get a camber wear..
so i need to know how long i can wait before i get my camberkit..
Old May 11, 2003 | 03:30 PM
qtiger's Avatar
qtiger
Unless you have lowering springs with a significant drop, your camber will not require a kit.
Old May 11, 2003 | 08:11 PM
cu3tip's Avatar
cu3tip
i have eibach sportlines, and it is dropped pretty far.. 1.7-2.2 inches..
how long do i have beofre i will start ripping through my tires..??
Old May 12, 2003 | 03:56 PM
ntegravtec's Avatar
ntegravtec
PENGUIN!
well.. i think it depends on your alignment. If your toe is off, it'll wear down your tires even more than just the camber being off. I've had mine dropped 1.5 inches or so... the camber is noticeably off, but my alignment is perfect otherwise. I haven't seen any unusual wear. Although, i definitely have more wear on the inside of the tire.
Old May 20, 2003 | 09:23 AM
b00gers's Avatar
b00gers
getting an alignement right after the drop is VERY important. after that, depending on the drop, you can go without a kit as long as you routinely rotate your tires.
with that drop, i would invest in a kit.
Old May 20, 2003 | 10:35 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
As long as your alignment is proper and you rotate the tires on a regular basis, you should be fine.
Shingo
