92 teg RS engine(B18A1) swap
Old May 11, 2003 | 04:12 AM
NVS's Avatar
NVS
That's Mr.NVS to you!
Default 92 teg RS engine(B18A1) swap
What possible engines can I swap my stock one for. I really want to put a prelude(h22, I think) in it. I've heard that you can pretty much swap any Honda/Acura engine with any Honda/Acura engine. True? False?
Old May 11, 2003 | 07:28 AM
Hans Stoner's Avatar
Hans Stoner
pimpin' south jersey
rebuild & turbo your motor!! :bigok:
Old May 11, 2003 | 09:14 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
A 1st gen B16A will go in pretty easily, as will a B17A. I would hate to see what you'd have to do to fit an H22 in there, since your engine bay is pretty cramped as it is. For simplicity's sake, you might want to stick to OBD-0, but you should be able to get any B series swap to work.
Old May 11, 2003 | 10:09 AM
RB's Avatar
RB
snitches get stitches
no you're mistaken. a 92 is obd-1, so he could get any b16a gen, a b17a would be a straight swap, the 94-95 b18c1 (which is also obd-1) will work perfectly, as well as any other b18c1. If you do buy an obd-2 engine, all you have to do is buy an obd-2/obd-1 converter for about $150.
An h22a is NOT a good idea. Not too many have done this, as you will have to custom make motor mounts for it, since no company makes a ready made motor mount kit for the G2 tegs (with regard to the h22a).
Old May 11, 2003 | 10:36 AM
RB's Avatar
RB
oh i just found this...
http://www.g2ic.com/tegtips/engine/15.html
click on "Engine Swap Guide" and then save it to your hard drive.
It'll let you know about all different kinds of swaps for both 90-91 (non-obd) and 92-93 (obd-1).
HTH
