installed neuspeed sway bar
Old May 10, 2003 | 10:06 AM
HYBRID's Avatar
HYBRID
Default installed neuspeed sway bar
last night i put in neuspeeds 19mm bar with endlinks. i must say it made a very drastic change, and i wonder if getting the type-r bar would have been a little too much.
the only problem i have and hope someone can help me with is that the stock bolts that hold the stock endlinks in place are too long for the neuspeed endlinks. should i get shorter bolts or put some more washers in? also can anyone provide specs for how much to torque down the lower control arm bolts and the endlink bolts? thank you for your time.
Old May 10, 2003 | 12:17 PM
XSrcing's Avatar
XSrcing
i would get shorter bolts. make sure they are at least SAE Grade 5 or higher.
Old May 10, 2003 | 12:25 PM
HYBRID's Avatar
HYBRID
any idea of where i can pick up a set?
Old May 10, 2003 | 01:55 PM
coletrain25's Avatar
coletrain25
At any hardware store, just bring in the bolt you have and ask a guy working there and he should hook with a shorter bolt.
Old May 11, 2003 | 11:38 PM
HYBRID's Avatar
HYBRID
thanks, do i really need new bolts though whats your opinios on putting some more washers in.
Old May 12, 2003 | 03:43 AM
pomansouth's Avatar
pomansouth
just get new bolts they arent much more then washers you might end up spending like 2 dollars. how much did you pay for the neuspeed sway
Old May 12, 2003 | 10:45 PM
HYBRID's Avatar
HYBRID
got it for $100. and all im going to do is put in some spacers.
Old May 13, 2003 | 09:44 AM
NoRiCeHeRe's Avatar
NoRiCeHeRe
As for the torque, I located some torque numbers in my Chilton manual for my Civic. So I would check in your manuals that you have. Post some pic's when your done.
Old May 13, 2003 | 10:59 AM
HYBRID's Avatar
HYBRID
i have no manuals i just tightende everything really tight. ill post pics this weekend for you later.
Old May 14, 2003 | 06:12 AM
BonzoAPD's Avatar
BonzoAPD
is this the front sway bar that you got?
