2003 civic 4dr 1.7 L Running lean
Old Jan 7, 2011 | 08:52 PM
cruzalekz's Avatar
cruzalekz
Default 2003 civic 4dr 1.7 L Running lean
car came in with severe misfire code (cel blinking), my co technician change the following not knowing that the misfire actually happens intermittently>>>:
with the following parts installed (car keeps coming back)
spark plugs, 4 coil on plugs, new fuel pump (identifix recommendation), cleaned egr and passages.
with all those replaced, i got a chance to look at the car today and i noticed it was running lean with LT fuel trim at +10 to 14%. sho rt term at 10% + side.
anyway, manager let go of the car but i know for a fact its gonna comeback again.
guys got any ideas??? o yeah , tech smoked the intake and no leaks there, no vacuum leak.
Old Jan 31, 2011 | 11:30 AM
Redline96LX's Avatar
Redline96LX
check the fuel filter, clean the injectors with that gas treatment crap, and check your 02 sensors. Also check for a dirty air filter. Then reset the ECU by disconnecting your battery for 3 minutes. Also check the crank sensor if you can, as well as the VTEC solenoid.
