All Motor...keep stock exhaust piping?
i plan to go with a moderately built all motor set up (180-190whp)..if i keep the type-r b-pipe, will i be choking my motor at all? or should i go for a bigger diameter? i plan on going with a more freer flowing muffler so this is only a b-pipe qustion. TIA
No, a fairly stock ITR will have a huge benefit from a 2.5". forget 2.25, not worth the time.
On a stock note though. On H-T.com there's a post about removing the bottleneck from the stock B-pipe. I've seen a handful of cars hit 200whp w/ stock cat-back that way.
If I remember later, I'll look. If you can't find it, drop me a pm.
60mm. i'm about where you want to be at right now. Also, it depends if you want to strictly top-end.
the wider the pipe, the faster allocation of the exhaust speed velocity at high rpm, but too wide and the exhaust pulses won't exit in a uniformed manner.
(2.75" for you non metric folks)
