Need help quick - How do I pull the crank pulley off?
In the middle of TB swap. I got the crank bolt out (finally) but how does the pulley itself come off???
I have tried to use a pulley puller but they don't look like they are designed for this. I really don't want to pry it off. Help!
1998 GSR.
1998 GSR.
Assuming you took the belts off, you should be able to pull it off. Maybe try to jar it loose with a dead blow hammer.
