Arrgggg, ran over a nail/screw! Help!
Ok, so I was coming home from the gym and I drove through some debris from a car accident that just happened...When I got home, I found a screw right in the tread of my tires!
The tires I have are stock now, but it was almost time to get new tires anyway...so I guess I could just buy a new set of decent tires, instead of wasting money on repairing it. Apparently the dunlop SP5000 is discontinued (?). I was looking at the Kumho Ecsta MX ($79 a piece) in size p205/50/R15. Anyone have any comments on these tires? How long do they last? How much grip do they have? Is it worth it?
I have heard the MX's are the shit. I just had a screw removed from my 205/40/17 Falken 451 and the shop that did it ****ed up my rim doing it so they are buying me a new wheel. A $20 job to fix ended up costing them $300!! If you decide to get it fixed, its not that expensive, but make sure the shop you take it to is reputable and does good work. I would get new tires, personally, the OEM Michellins suck!!
Not hating on the MX's, cuz i kno they're great tires too, but for 79 a pop u can also get bridgestone s-03s in 195/50/15....hehehe
DB Squad
Integra Forum Moderator
DB Squad
Is the hole in the tread or the sidewall?
Sidewall holes, while rare, will KO the tire.
Tread punctures are wayyy easy to fix... assuming you get em all. :doh:
depending on your rim, it could be as easy as fix aflat in a can. not on aluminum though. you can throw a plug in it in aprox. 2 minutes though for under 10.00 for tool and a handfull of plugs. just a thought
