Best amp for around 200 bucks??
Old Apr 29, 2003 | 05:43 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default Best amp for around 200 bucks??
Well since my amp appears to be fried now i need a new one. Whats a good amp for around 200 bucks that could power two Audiobahn AW120T's (500watts rms a peice) wired for 2 ohms. Thanks
Old Apr 29, 2003 | 05:49 PM
Randy12vp's Avatar
Randy12vp
When you're working with a budget as little as $200 your best bet is to look on e-bay and try to find a deal. Good luck.
Old Apr 29, 2003 | 06:08 PM
SiClone's Avatar
SiClone
X-Moder8er
Sounds like you need a JBL BP1200. You can get a used for $200 easily or else spend $50-75 more for a new one. 1200 watts at 2 and 1 ohm.
Old Apr 29, 2003 | 08:01 PM
ToadSi's Avatar
ToadSi
That's a skimp budget for those speakers. Dual or single voice coil? If single voice, you could get a new bazooka ELA5001. not a bad mono amp for 200.
Old Apr 30, 2003 | 04:10 AM
moofoo's Avatar
moofoo
Tastes like DonkeyBalls
Yep best bet is ebay.... you might be able to find some... but the JBL does make the advertised RMS... so go with that!!
Old Apr 30, 2003 | 02:04 PM
lil_1_2002's Avatar
lil_1_2002
sorry to jack ur thread, but i am also lookin for an amp, i was thinking of buying a 4channel amp for 2 audiobahns AW1000Q, since i dont ahve much to spend right now, i was thinkin of buyin a small amp to push em, and then when i ahve enough buy the bigger amp and then i can use the smaller amp for my components in the front, any suggestions on amps, i also would like to spend only 200-300 for a decent or good amp? and i'm a noob with amps so anything would be great hehe. (suggestions that is)
