Headgaskets
Old Apr 17, 2003 | 04:26 AM
ManTiS's Avatar
ManTiS
NinJA
Default Headgaskets
If I'm getting my engine bored out +0.5mm, then I'd want a larger bore headgasket as well, correct? Will it work with a stock headgasket?
Where's the best place for cometic gaskets? They make thicker ones, right?
Old Apr 17, 2003 | 05:57 AM
rev's Avatar
rev
Head gaskets are designed to be used for an oversized bore already, so just use the one you get from the dealer/parts store.
Old Apr 17, 2003 | 08:11 AM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Word. Honda makes pistons in .25 and .5mm overbore, but they don't have overbore head gasket part numbers, so the same gasket works with all of them. I would personally run an OEM gasket and spray it with a couple coats of copper spray. The OEM Y8 gasket is only like $20. If you really want a Cometic, you can get them from a lot of places. You'll probably want the HP gasket, which basically has o-rings to help seal the combustion chambers.
http://www.nipponpower.com/engine/ga...ometic_hp.html
http://www.raceeng.com/ShowSuppliers...=IMP&subcat=GS
Old Apr 17, 2003 | 03:09 PM
ManTiS's Avatar
ManTiS
NinJA
I already have the Y8 headgasket and a can of copper spray. I'm all ready, don't worry. I was just curious.
