Timing belt price ?
Old Sep 20, 2010 | 01:01 PM
gingas's Avatar
gingas
Default Timing belt price ?
I wanted to know do you think $475 good price on timing belt. Another thing as far as a performance upgrade while getting it done. What do you recommend to get. Cams etc.. It's a 98 GSR.
Thanks
Old Sep 20, 2010 | 01:12 PM
Spec R's Avatar
Spec R
Thanks
timing belt, timing belt tensioner, water pump, water pump gasket, thermostat, thermostat gasket, cam sprocket gaskets (o-rings), valve cover gasket, honda type 2 coolant, power steering belt, alternator belt.
thats a comprehensive list of what to get done.
DB Squad
Integra Forum Moderator
Old Sep 22, 2010 | 08:10 AM
ReaperOne's Avatar
ReaperOne
I agree, had mine done a little while ago and actually found a honda dealer on ebay that sold me a package with all of the above minus the thermostat and gasket for like $120.00 shipped. . . I had a buddy help with the labor, so it came out to be just about the parts for me, but if you are doing the timing belt, all of that should be changed as well.
As for performance upgrades, it will be a little more that just plug and play with cams as some require you to change your retainers and/or retainer springs to be able to handle the new camshafts and that is machine shop work to change retainers & springs(unless the shop you go to is familiar with it). You have to remove the head to change out the retainers & springs and if you remove the head, you should just go ahead and change the head gasket as well. . .
Old Sep 25, 2010 | 10:51 AM
cruzalekz's Avatar
cruzalekz
No cams bro, will not pass smog. YEAH YOU WILL GET HP BUT GAS MILLEAGE WILL SUFFER TOO
Old Oct 1, 2010 | 05:42 PM
gingas's Avatar
gingas
Default Update on timing belt prices..
Yeah, I decided to call a few more places for prices on timing belt job. Well, one place I called was in No. VA. Karen Radley Acura in Woodbridge VA.
They bumped their F?????G heads. They want $1300. Don't go their. Way too much.
Haven't had belt done yet. I just wanted to compare. As for cams I'm in MD so I don't have to go through with the smog issues.
Thanks for the info
Old Oct 8, 2010 | 06:39 AM
Khazzy's Avatar
Khazzy
The know nothing kid.
Thanks for the info
i f'n hate MD's emissions and inspection...they are VERY picky
Old Oct 10, 2010 | 05:14 PM
gingas's Avatar
gingas
Yeah, I agree with ya on inspection.
Old Oct 11, 2010 | 07:53 PM
Spec R's Avatar
Spec R
but its awesome when you pass
DB Squad
