Electric wiring
Old Apr 13, 2003 | 01:17 PM
FibaRacing's Avatar
FibaRacing
Default Electric wiring
I am wondering if anyone knows if there is a 12V wire already inside the passenger compartment, that i can run a small FM/modulator off of, or if I have to run a seperate wire from the battery through the firewall?
Old Apr 14, 2003 | 05:06 AM
RSXoholic's Avatar
RSXoholic
the anti-rice
tap into the 12v power wire for the power port.
Old Apr 16, 2003 | 02:48 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
There should be one under the dash on the drive side. The fuse pannel should have some kind of extra place that doesn't have a fuse in it. You could tap into there and then put a fuse in. I am not sure what fuse rating though.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
