car wont start - where do i start trouble shooting?
Old Jul 16, 2010 | 12:59 PM
ReVenGe's Avatar
ReVenGe
Default car wont start - where do i start trouble shooting?
Hi guys, im back.
anyway. i started my civic, drove it out of the garage. turned it off.... came back an hour later - i have power, but nothing happens when i turn the key all the way - its just like how it wont start without the clutch pressed in... except for that the clutch is.
fuses are fine
i checked the clutch sensor - plastic thing is not stuck in...
im :run:
Old Jul 16, 2010 | 01:27 PM
Shameinator's Avatar
Shameinator
Check your battery
Old Jul 16, 2010 | 01:32 PM
ReVenGe's Avatar
ReVenGe
battery is fine, 12 volts - the starters just not engaging.
Old Jul 17, 2010 | 01:52 AM
Shameinator
Then my guess is its your starter. I had this problem on my 93. Give it a good smack and see if it starts. If it does then your starter is bad if it doesn't then your starter is probably still bad.
Old Jul 17, 2010 | 03:39 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Also could be the clutch switch. I have problems in the winter since the cold shrinks things. I had to wiggle my foot to get the car to start. I guess I need adjust it a little
Autocross Help Page
