Del Sol Hydrolock...Need help.
Old Jul 12, 2010 | 08:04 PM
DelSol1967's Avatar
DelSol1967
Default Del Sol Hydrolock...Need help.
I found alot of water in the first 2 cylinders closest to the front of the engine. I got it out. It has been 2 days drying out and I put a bit of Marvel mystery oil in the cylinders to see if it would break lose. So far I have tried to turn it over and it does not move. Should I try to pop the starter continously? Is there a way to turn the crank manually? I cannot see how to get a socket in there.
Old Jul 13, 2010 | 02:21 AM
fathergoat's Avatar
fathergoat
:3
there is a hole in the inner splash guard in the drivers side wheel well. you can get an extension and I think it's a 19mm socket through there. the motor should turn counter clock wise. keep in mind though that if you took in water while under heavy throttle you could have seriously damaged the internals. hopefully that isn't the case for you.
